- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
My mother has forgoten the admin password for her Sony Vaio. Is there a way I can reset it? The computer has not been used since set up so don't need to worry about loosing any data. My brother has suggested re-installing windows 7. Will this work?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Please try the good advice given by passwordreset but if nothing there helps, you can reset the Vaio to factory settings by tapping F10 during boot - when you see the Vaio splash screen.
If you want some guidance on how to do this, either look at the Recovery Guide on the support page for your model or tell us the Vaio model so we can give you a link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How to Unlock Windows 7 Password?
unlock windows 7 password
http://www.recoverlostpassword.com/article/unlock-win7-password.html
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The easy way is to reset Windows 7 password. No need to reinstall the whole operating system and software installed on your computer. Check out this guide:
http://www.top-password.com/knowledge/reset-windows-7-password.html
It should be helpful for you.
Good luck!
