Sony Vaio AR31S shows everything that is black as green!
profile.country.fr_CH.title
dreamydayz
Hi
I have a Sony vaio ar31s which has of a 2 days ago has lost the ability  to display the color black. Anything that was black is now green!
I've connected to different monitors and have not been able to extend or duplicate my display on either of them.
I can however using the hdmi port onto my flat screen TV.
I don't think its the inverter as the display works but just shows black  as green. I'm more drawn towards the Lcd cable or laptop monitor.
Is the only way to test lcd cable is to replace it?
Would you concur that it is more likely the cable or the monitor?
many thanks
let me also clarify that my desktop is normal apart from anything the screen draws that is supposed to be black comes out green.
Icons, desktop themes, programs, web pages etc...not solid green.
thanks again
Message was edited by: dreamydayz
0 REPLIES 0
