Looking for a new notebook and I was wondering if the Sony Vaio Fit Multi-Flip has a changeable hard drive and does it use SATA? Looking at the 14 inch more specificly if that matters.
Solved! Go to Solution.
Hi Caszum and welcome.
Changing the drive would almost certainly invalitate the warranty.
However, if you choose to buy a CTO (customer configured) Vaio the following drives are available to choose from: -
You can see all the configuration options here: -
http://www.sony.co.uk/customise/vn-fit-a
Thing is I already have an spare SSD but not all laptops are made easy accessable and some even avoid warrenty.
