Sony Vaio Pro doesn't work without charger
ribagorza
Recently my Vaio stopped working on it's battery. It only works with the charger connected. On the battery information it says that the battery is at 79% (at which it has been for a while now), but when I take the charger out the computer shuts down immediately. Does anybody know what the problem is?
11 REPLIES 11
ribagorza
Hi!
After talking to sony, they decided to send me a new battery. After maybe a month I got the battery, but i didn't know how to change it. So I went here to ask for help and saw that you guys had come up with a solution. And it worked for me also, so thanks! Now I have a working battery in my vaio and a new battery from sony. So I'm thinking I'll save the new battery until the one I have starts getting bad. But the problem is I don't know how to change it, so I was wondering if anybody knew? My model is SVP1321C5E. Tried searching for it, but I didn't find anything.
mhmahmud181
Having the same problem with my vaio pro 13, battery indicator stopped at 73%.
Been using this unit for the past 2 years, is it my battery need to be replaced?
