SONY VAIO SVE1513K1ESI
profile.country.GR.title
efizaf
Hello from Greece. I am writing for the first time and this is my problem: I have a SONY VAIO SVE1513K1ESI and a few days ago has just stopped regognising the keyboard. In the system properties it shows that it works fine. I have removed the drivers of the keyboard and then re-intalled them, but the problem still remains. Do you please have any other suggestions?Thank you in advance.
Tags (2)
Win_88
Specialist
Hi efizaf,
I wonder if the keyboard works in BIOS or if you are able to get into BIOS at all? If you get into BIOS (by pressing F2 during boot), test the keyboard in the password section which lets you type using most of the keys. If you find the keyboard to be working, try resetting the BIOS to defaults.
Hope this helps,
Win_88
