Vaio VGN NW 120J Bios
BigBossOfficial2
Hi. I need help with my outdated PC. So My Problem Is I Just Installed The BIOS Update. I need the advanced options in BIOS. But there is no advanced options in bios menu. What can I do about this?
Tags (3)
This looks like a Sony USA model so I would seek help on the www.sony.com website.
Is the BIOS you downloaded the one from that website here:-
https://esupport.sony.com/US/p/model-home.pl?mdl=VGNNW120J
This is update is to enable virtualisation but Sony lock down other advanced BIOS features and these cannot be accessed. You may find BIOS hacks online but these are very dangerous and I would not recommend trying them as you may brick your VAIO.
Which additional features are you looking for? Some features can be controlled with Sony Utilities.
