- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Sony Vaio SZ2M/B Turning off
i have just bought command and conquer 3 and i find when i play it my laptop cuts out, half way thought the game, and get extremely hot, is there something wrong with it i have only had it for like 5 months so it is still in warranty, should i call Sony up, i have run Intel thermal analysis tool and it say the chip gets to 90c so im guess that very hot, it is kept on my desk so it has good venation.
ali
thx for the help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Alastair825
The cause of your vaio shutting down could due to overheating...!!
what is the Normal running temperature of your vaio..?
If your unsure, mobilemeter is a handy application to use..
If your Vaio is overheating during normal use then try clearing the cooling vents of dust with compressed air (you should be able to get this from your local PC shop), holding the can upright give the vents a short blast from a distance of approx. 10cm if you hold the can to close you could damage the fan..
