Sony Vaio VGC-VA1 TV Tuner Problem
profile.country.bg_BG.title
Amateur
Hi all im new here.I have problem with my sony vaio vgc-va1.Tv tuner don't have out ports only in but when i plug my tv antena cable in the tv tuner nothin happens i media center.Can anyone help me to watch tv on it and record channels?I live in Bulgaria.
6 REPLIES 6
Hi Amateur and welcome.
Are you using the original Windows XP Media Centre Edition?
Have a look at your User Guide Page 33 to see if anything there helps.
ftp://ftp.vaio-link.com/pub/manuals/Desktops/VA1/VA1_H_EN.pdf
Are your TV Broadcasts Analogue (UHF) or Digital (DVB)?  Like the rest of Europe, I expect you are transfering to Digital. Have you tried running Media Centre Setup to choose your country and search for TV Channels?  I don't think your Vaio is capable of receiving digital broadcasts without a set-top-box.
:thinking:
Amateur
Hi Blencogo,i tried from Windows Media Center Edition but when i try to set up the signal it wants Contry Code.I don't have the code.Im usin only cable tv,unplug from tf and plug in PC-TV Tuner.
Amateur
Hi again,i plugged cable in the tv and then from tv out to pc in 3-3 red,white and yellow ok what am i watchin on tv it appears in fly2000tv i record video with bad quality and no sound?Any ideas to repair it?
You would normally connect the co-axial cable to the VHF/UHF ariel socket and run WMC Cable Setup.  If you have a Cable Box, you need an IR Blaster.
Make sure you have your Country Settings set to Bulgaria in Control Panel -> Regional and Language Settings.
On the start screen, scroll to Tasks -> settings -> TV -> Set Up TV Signal.
http://windows.microsoft.com/en-GB/windows-vista/Set-up-a-TV-signal-in-Windows-Media-Center
:thinking:
Amateur
Ok i didnt know the thing with the regional and language options.I'll try tomorrow.And after that i will messege here.
Amateur
Ok i changed the regional and language settings.When i entered my postal code in media center it seems that my Country its not sported only USA and Canadian...no idea what to do...
