sony vaio vgn-aw11m recovery cd ?
madoyle99
         can i set Tham ?    sony vaio vgn-aw11m
             recovery cd ?
Martin
Message was edited by: madoyle99
Message was edited by: -Cass-
Removed personal information as personal details are not allowed to be shared on the forums in order to protect users identity
Thalamus.
Champion
Hi Martin,
Welcome to questions & Answers..
Is your Vaio still booting up into windows.?
If so then you should be able to create a set if recovery discs yourself without the need to contact Vaio support.
If you are unable to boot up into windows then normally restarting your vaio and pressing the F10 key when you see the Vaio logo should start the recovery process using the hidden HDD recovery partition..
Do any of those options help, if not give us some info on your problem & we may be able to help without the need for you to purchase a set if recovery disc's..
