Hello,
My laptop is Sony Vaio VGN-FW51ZF/H. I am thinking about changing graphic card.I heard that it is possible with this model.Can someone tell which graphic card will be compatible with my laptop. My next Question is if I can change something else inside it like proccessor or motherboard if yes please list me ones that will be compatible.
Hi Xarels,
The graphics chip is soldered to the motherboard and therefore upgrading is not a viable option.
You may well be able to upgrade the CPU (no idea which will be compatible – do your own research – existing processor is Intel® Core™2 Duo Processor T9600). Changing the motherboard will set you back not far off the cost of a new laptop.
Your model shipped with 8GB RAM and this is the max supported.
Rich
