Sony VAIO VGN-Z56GG screen problem
olryst
Hi, my Sony VAIO VGN-Z56GG has aproblem with the screen.
For some reason it is very dark, I can just make out stuff on the screen but not enougth to use it.
If I plug it into a monitor it works fine.
Any ideas?
Thanks.
Message was edited by: olryst
rich912
Hi olryst,
This usually indicates a backlight failure, lose connector cable, or more usually an inverter problem.
Rich
Go n-éirí an bóthar leat
5 REPLIES 5
rich912
Hi olryst,
Rich
olryst
Can the backlight or inverter be replaced on there own or do I need to get a new screen?
rich912
Both can be replaced individually without the need for a new screen.
Rich
olryst
The inverter is the rectangular circut board under screen?
Where is the backlight located?
rich912
Yes, the inverter is usually rectangular with connectors at both ends and normally located at the bottom of the screen.
The blacklight(s) are behind the LCD screen.
Rich
