For voice recognition software a decent microphone is connected to a PC via supplied jack sockets. I am told there are USB devices that provide such jacks for notebooks. I would like advice on what to use and I assume some software bolt on is needed.
Ern
For most uses, you should be fine with the headphone/microphone jacks that almost all VAIO models have. Any microphone/headset that comes with a 3.5mm plug should work fine for voice calls, simple recording jobs and voice recognition and is also mostly dirt cheap.
Only when you need a line-in instead of a microphone in or when your VAIO happens to not have a microphone input is the use of a USB soundcard a good idea.
addendum:
If you use a professional microphone and mix pult, you may run into a group loop hum issue. There are filters that you can use to counter that.
Thanks for your response
My Vaio is a VPCSBIV9E and has no jacks.
Ern
I'd try the internal microphone first. If that is no good. you can try a bluetooth headset if you already one one.
The cheapest option besides the internal microphone should be headset with a USB connector, these are recognized just like a USB soundcard would be and are quite common and affordable.
Check the price of a USB headset you like with that of a USB soundcard plus headset.
I hope this helps.
Hi steph
I am most grateful for your advice, I will look into these options, and feed back.
Ern
