HI everyone
i am delighted to join this forum and recently bought asony vaio laptop(sr39vn/s)and
I,ve got a question abt my laptop battery there is little movement after you clicked in is that normal for vaio laptop? iam sure i fitted the battery correctly. if not normal is it something wrong with the design?
any advice would be appreciated
Thank you
Hi b18c and welcome to Club Vaio.
I cannot recall any posts about this problem before - perhaps another SR user can comment. In the meantime, perhaps a small amount of packing with something that will not melt?
If you don't get any response from other SR owners and you are still uneasy, I would telephone Sony Support and ask them for advice.
Click on 'Support' at the top of this page and enter your Vaio model - then click on 'Get in Touch'.
thank you for your advice and it could be the design of the laptop to prevent damaging the battery pin
Hi b18c,
if you've the time you could visit a local stockist check if the display models battery has the same amount of movement as you've noticed on your SR39VN.?
Hi b18c,
yer that,s good idea and i sent a message to sony support so let wait and see what they had to say
i went to the sony store to check if other laptop(same model) does the same. yer it does but mine has bit more movement than that. i checked Z series and no movement at all. it might be a common problem on this model. i,ii update once i ,ve got confirmation from sony. if any has a same model i,d love to hear from you
Thank you
Thanks for the update..
yer I spoke to sony and they said its not a common problem on this model. unfortunately its only for my laptop and i put the blame on the people who designed it. it say made in china.
when i bought from the retailer it was in the box unopened. who knows someone might have used before? or diplay one put back in the box.
