Hi, I installed Windows 7 on mi vaio and now I cant use the function keys, particularly problematic when giving powerpoint shows.....
anyone know of a fix for this puta of a problem?
muchas gracias
Garfio :smileygrin:
Hi Garfio and welcome to Club Vaio.
You don't tell us what you have tried so we can only guess.
Have you installed the Vista Drivers and Utilities for your model?
Go to the Vista Upgrade download page for your model here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-BX196VP&os=alt
Download and install IN ORDER:
1. Sony Utils DLL - 7.0.00.11210
2. Sony Shared Library - 3.0.00.10180
3. VAIO Event Service - 3.0.00.13110
4. Setting Utility Series - 2.0.00.11270
You may have to try the installation sequence more than once to get the Fn keys to work.
