Start up/Shut down
szesze
Start up/Shut down
I have just bought a VGN-S4XP and I find that it takes an age to start up and shut down. Is this normal? And is there anything that can be done to speed it up?
8 REPLIES 8
chippez
U have to check if the programs are correctly closed on shut down , on start up its normal if slow on battery as it is on main, programs to accelerate will decrease your battery lifetime so u have to live with it!
blue1901
Download Mike Lin Startup manager, disable any application that u dont use, and u can enable them back again, its a great program, he won awards for it. http://www.mlin.net/StartupCPL.shtml
blue1901
and from Yahoo messenger preferences, uncheck stat with windows because this slows down the PC a lot!
kee-lo_
Tune Up Utilities is a very good program and will sort out registry issues and start up programs
ant1uk
mine starts up fast no problems at all
blue1901
Whats "tune up utilities"?
chris_lewis
What!!! you mean you dont know something, wow!
Look here TU 06
C
blue1901
Look here TU 06
C
YES i DONT know whats tune up utilities, is it a problem to ask about something on this forum! r ppl who ask stupid?
