upgrade the memory for my PCV-RZ422P
jimbo41
can any one help?
Do I need to replace memory in pairs in my RZ422P?
I have the following installed and I want to install a 1GB PC-3200 DDR SDRAM 400 Mhz.
will I have to place 2x512MB sticks?
Slot 1 : 256 Mb
Slot 2 : 256 Mb
Slot 3 : Empty
Slot 4 : Empty
thanks for any help
jim
6 REPLIES 6
kee-lo_
If it's RDRAM it'll have to be 2 more 256MB sticks
Otherwise if it's SDRAM just get a 1GB stick
rich912
This particular series comes with various configurations of memory, but all have banks of 1 - yours has four 4 banks of 1, thus you can install one module at a time in any of the 4 banks.
Have a look at the Crucial site for further information and use the Crucial system scanner.
As they are offering a 1GB module, and guarantee that it is compatible, there should be no problems.
Go n-éirí an bóthar leat
jimbo41
thanks guys for the info
how will i know if my pc is pc 2700 or pc 3200
jim
rich912
jim
Use the Crucial System Scanner, this will reveal all, or download Everest Home Edition.
jimbo41
thanks again
its 3200
jim
jimbo41
I asked a few weeks ago about memory and you gave me great information. I purchased a 1GBPC-3200 DDR 400mhz stick. When I install it the monitor will not work.
Do you know if the pc supports duel channel (memory with chips on both sides of the stick?
I will welcome any help
Jimbo
