Hi all, I just got a new VPCL13M1E but unfortunately I’m having problems with a sticky mouse. I would be grateful for any ideas on how I might solve this problem.
I’m using the wireless mouse that came with the PC
Many thanks
Solved! Go to Solution.
Try replacing your mouse device or your mouse pad. Be sure that you are using running it in smooth area.
Sorry, I don't have a solution, but do have the same problem. I've had the VPCL13M1E for around nine months with no problems. I've tried updating drivers and rolling back after the last windows update but no sucess.
Going to try a wire mouse for a few days to see if this helps.
Regards
