SVF13N1C5E - Screen Resolution Keeps Changing..?
HardDriver
All,
Anyone experiencing this:
I can set up the screen resolution 1920x1080/small or regular icons etc set up my tiles on the Start Screen in 8.1 and all is fine.
Restart/Close Lid & Open and it changes..?
I can go from 4 Rows on the Start Screen to 5 or 6 it varies.  On the Desktop the Tool Bar at the bottom is small or large to.
Any ideas or fixes will be greatly received 🙂
HardDriver
Done it...
I had my other Laptop and Flip both on Windows 8.1, with Skydrive sync settings both syncing - caused conflict.
Have disabled both from doing this - fixed.
4 REPLIES 4
takrzem
Nope, but I would first check if your display drivers are okay and the latest ones
HardDriver
Done it...
Thalamus.
Champion
Hi HardDriver,
Thanks for taking the time to post an answer to your question, hopefully this will be of use to others with the same problem..:smileythumbsup:
HardDriver
actually it's back!
thinking now it's a Windows glitch - updates requied....
