- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
SVF15A1M2ES fan speed issues.
Hello, I've owned a Vaio SVF15A1M2ES model for about 2 months now and I seem to have a annoying issue with the fans. The laptop is generally silent but every 2 minutes or so the fans with speed up and be noisy for a while then go back to silent and rinse and repeat. I use speedfan to check the temps and they don't change at all, even if it is getting a little hot it shouldn't be going so loud. Looking at task manager and everything will be on 0% usage except for memory which is around 20%. I am on Windoes 8.1 if that helps.
Any help would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
bumo
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi JPClose and welcome.
What version is your current BIOS?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
As far as I am aware that is the latest update for my laptop.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
There is a version R0230DD but it is not listed for your model.
I'll contact Sony on Monday and try to get some clarification.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you! Is that likely the issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi!
I had a similar problem with my Sony Vaio Pro 13, model SVP1321M9EB.
The fan turned off and on and was really annoying.
I opened the Vaio Control center. Under section Power and battery a changed the setting for CPU and Fan from Standard to Silence.
That helped, and I did not notice any change in performance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Still not managed to fix this, really annoying problem!!
