Temperature Problem - FS215S
seronal
I have a VGN-FS215S VAIO and i bought it excatly 5 months ago.
And it hadn't any problem but around 1 mounth it gets hot.
Temperature is going 72 degrees when i make surf on net.
Also when i play game it's temperature is getting 87-88.
Is this normal or what?
(I use Notebook Hardware Control Program and i check temp with that.)
Please help me as soon as possible because i 'll going to service. If it is normal then i won't go so please tell me something.
7 REPLIES 7
kee-lo_
That's not good really, puts a strain on the hardware.
Get a can of compressed air and spray the vents, from around 10CM away
seronal
Can you more explain your message, unfortunately i couldn't understand well.
(My English is not good, sorry :cry: )
kee-lo_
Vous parlez Francais?
If not then I'll explain it in more detail
seronal
I think he is Francais then???
I can't understand that what you wanna say.
Will you or can you help me or not?
I really need help as a vaio user!!!
kee-lo_
OK
You need to buy compressed air from your electrical shop and spray it 20CM away from the vent
Ugh I can't find Turkish translators!
rich912
This article may help to clarify things....
Go n-éirí an bóthar leat
kee-lo_
Maybe eatil can translate for you?
