the vpcf12moe fan was broken
vapyj912
now, the vpcf 12moe fan was broken, I want to replace it, but I do not know where I can buy it, pls help me, thank you. I want to replace it by myself, so I need to buy this mode of fan, or other mode of fan which is also can replace it.
Tags (2)
LaptopSpecialists
Only option I can give you is to contact Sony :slight_smile:
If these do not help you out, there are other places such as Ebay where you could find the item. You would need to locate a part number from the fan inside your machine and just search this model number on Ebay.
Message was edited by: Thalamus.
Advertising with link to commercial website/personal information irrelevant to the thread
