touch pad tapping detection needs a delay
epost
I often find that while i move the mouse using the pad, i tend to lift my finger for a very short moment, and then touch the pad again to continue moving the mouse pointer. This behaviour is interpreted by the touch pad driver as a tap. So i often find myself unwillingly dragging stuff over the screen, messing up stuff.
How can i solve this? Is there a setting that allows me to configure the driver to wait for a certain time after the last mouse pointer movement ends, before creating the tap event?
grtz
edvard
Thalamus.
Champion
Hi epost,
Welcome to Club Vaio, :slight_smile:
You can adjust the tapping settings in the Mouse Properties, this can be found in Start > Control Panel > Printers and Other Hardware > Mouse..
A new window will open then click on the Tapping tab to adjust the settings...:smileyhappy:
epost
Hi epost,
He he, yes i'm a proud new owner of a vaio, love it 😉
About the tapping, yes, i tried that, but what i find is that it simply allows me to set something that isnt relevant: what i'm looking for is how to set a delay after mouse pointer moving BEFORE it starts accepting a tap. This would then prevent accidental tapping.
grtz
