Hello
I have a problem I have two Networkcards in my Notebook and I want to that only one Card can connect to the internet.
hI there, just go-to device manager and disable the one that you dont want to connect to the internet with.
hth
Yes I kmow this but I must use both cards because one card should make the connection to the Internet and the other (older) card is for the peer to peer conecction to my desktop. The problem is that both cards can connect to the internet and sometimes Windows take the slower connectin with the old card.
Right click the connection you want and set it as the default
