upgrade - a417m to 2GB RAM
mfgiesen
does anybody knows where i can get
2x1gb ram for my vgn-a417m?
need a german shop or seller.
please help.
greetings,
markus
8 REPLIES 8
robpaxton
Crucial are a good supplier.
feederfan
Be warned though, unless you want to some serious GFX or Video editing, it is a complete and utter waste of time, and even if u do want to do that, your processor wont be fast enuf to support it.
Windows aims to maximise memory use, so even tho it may look like you dont have much memory available, it doesnt mean increasing it will improve performance!
mfgiesen
it's because my macromedia studio and photoshop loads about minutes and this is gettin me angry...
so would you suggest 1GB would manage this too?
actually there are just 512MB installed and wether I am working too fast or machine is too slow. ^^
thanks,
markus
feederfan
I use macromedia studio on my desktop and 1GB is more than enough! you definitly dont need 2GB
kee-lo_
You don't need 2GB, but when you have Photoshop and Macormedia software open you'll see a difference
TygerTyger
Unless you have a tiny amount of RAM, no program should take minutes to load. I use Photoshop on 512Mb and it runs just fine. You have a bug in the works somewhere...
kee-lo_
When I had a 1Ghz CPU and 256MB it took around 45secs to start Photoshop 7, but that was normal for the time, so it really shouldn't take minutes on that VAIO
mfgiesen
too late ;o)
but I will keep you informed about the performance.
