sfxx25
upgrade cpu on FS215B
can anybody tell me if i can upgrade my processser on my FS215B from a centrino to a centrino duo processor.
any infomation given is grateful received
frannys
No sorry,if your system came with a single CPU,then thats all the Mainboard would be built for.To run a Duo you need a Duo capable 775 socket and the appropriate Chipset too.Also a normal Dual Core Mainboard cannot use the new Conroe Cpu,the Mainboard has to be Conroe Certified and with the correct Chipset too.A Conroe board can use both types of Dual CPUs.Same rules for AMD too.
