Upgraded VAIO TZ Series to clean Win7 - How toggle bluetooth?
HiveGuard
I upgraded my Vaio VGN TZ 11 to a stundent Windows 7 Home Premium. So far it workes fine and really boosts my system. Nevertheless, i got some problems installing the bluetooth stack from toshiba distribiuted from sony for the OEM Vista came with the TZ.
I can´t install it because I can´t activate bluetooth without the desktop-thingie (plug-in) - As far as i know there is no way to toggle BT via Fn+(anyKey).
So everything workes except for bluetooth an backlight-controll (Fn+F5/F6)
Any solution?
Hi HiveGuard and welcome.
You need to install the Software Switch for all wireless network connections. You can download the Vaio Smart Network Utility from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VGN-TZ11VN_X
You will then have to update it by clicking on the 'Updates' Tab and installing the Vaio Smart Network Update.
:wink:
