Vaio A series
Loosing Keys on Keyboard
This computer is a <profanity removed by moderator>
How many keys did you loose?
Just push them back in
Do you mean the keys are greying out? If so I have had the same problem and wished I had covered the keys will several layers of cling film or got a keyboard protector that suits from a computer shop. Vaio need to fix this low standard keyboard problem but my hardware is all going strong.
Very inteligent answer...they just breake
Yeah I'm the dumbass round here. The 'Lo alway knows. This is the first time I have heard of the keys breaking....wow.... you must have heavy fingers. Maybe instead of cling film, put bubble wrap on the keys...when they pop you know you must stop.
Here you go in Portuguese
Eu tenho estupenda bunda ao redor aqui!!! Pode 'Lo saber isso! Esta e a primeira vez que eu escuto que quebram as chaves .. wow.... vc deve ter os dedos pesados!!!! Talvez, em vez de aderir a pelicula, coloque o envoltorio da bolha sobre as chaves... quando estalarem voce deve parar!!!!
Glad to see tyour 'hardware' is still going strong at your age Beardo!:smileygrin:
I'm becoming a super cuaca man, Jumpy. Practise makes perfect especailly if your wifey is a Brazillian. There isn't 184 million of them just because they're catholic.
you'll be giving Sting a run for his money next matey!:smileygrin:
Is he called Sting 'cos he's got a really small .....?
How did 'old heavy fingers' get on then? Perhaps it was the armoured gauntlets.:smileygrin:
This is a bit like "message in a bottle" (I know it was the Police)
If they're broken, then speak to VAIO Link
Jumpy: LOL @ the French in the sig, doesn't make much sense does ti?
