I just bought an AW11S and after starting it up for the first time, the screen has some serious light bleed at the bottom 3 inches. This is particularly pronounced in blacks. I have two 'standard' screen vaios, and they don't bleed to this extent. I also checked it against the FW11Z (another dual-lamp screen) at the sony shop and it had practically zero light bleed.
How does sony quantify how much light bleed is acceptable, as I'm REALLY unhappy with this. The laptop is marketed with the blu-ray player, and it's just woefully inadequate with ligh bleed at the bottom of the screen.
Any advice/experience with this laptop would be appreciated.
Thanks.
Hi vaiococh,
If it was me, I would return it to the shop and ask for a replacement or a refund if it is less than 28 days since you bought it. The shop will say that you need to send it to Sony, but legally the shop is responsible if the article is sold with a defect.
That said, most screens have some light bleed as you say - I cannot see it and you can - but if you are really unhappy, take it back.
Hi vaiococh,
Hi there
Can you show us a photo of the bleed?
Hi there
Wow that does look bright to me. I would not be happy at all.
Unfortunately if they say that is acceptable then there may not be much you can do, although that is 'their' technician who may have an ulterior motive.
Are there any other display models in the store you purchased from?
Or in another store for comparison?
Have you contacted Vaio Link yourself to enquire about this?
At the least you could find out their policy and their defined acceptable bleed levels.
If its due back soon you could wait to contact vaio-link when you register it.
If you can't wait then you could certainly contact them to advise you
