bar47
vaio fan
Hi there can any one help I have upgraded my vaio pcv-lx1 to xp pro only thing is the fan is now running fast and loud all the time, never did this with millennium,
I all so have put bigger hard drive in and memory to. Would be grateful if any one has any I dear on how to sort this out, many thanks
4 REPLIES 4
kee-lo_
Have you installed all the utilities?
bar47
ermm not sure what you mean my friend?utilites?,any way you can help me on this i would be very greatful to you
kee-lo_
On VAIO-Link theres a download called Sony Utilities, if you download them and install it might help.
jammold
If you click HERE you will find the link for Preinstalled Drivers And Utilities for your computer.
Make sure you read the instructions on how to install them successfully. This may make the fan run more silently after installation.
