Vaio fs415b Problems needing solved
MORLICH
Hi all, I thought I should make a thread on this type of laptop with all the slight problems, maybe nothing to do with Sony, but OS problems.
- Sometimes when I go to switch the laptop on it boots up (then a log off window comes up and then the laptop shuts down, on restart it boots up fine, has been doing that since I bought it but usually starts with a black screen and then switches off, weird.
- Brightness levels lowered creates a high pitched noise from screen
- The scroll on the touch pad stopped working a few days ago, anyone know how to switch it on again?
I would be very grateful for any help and advice, thanks
Thalamus.
Champion
Have a look at this similar thread ..
Go to Start > Run type devmgmt.msc and press OK, Device Manager window should open, double click Mouse and Other Pointing Devices.
Do you have a Alps pointing device listed or something different..?
If Alps pointing device is not displayed in Mouse & other pointing devices, select the 'Driver' tab and click on Update driver.
A new Hardware Update Window will appear, select Install from a list or specific location (advanced) and click next
The window now changes select 'Don't search I will choose the driver to install' and click next.
If 'Alps Pointing-device' (possibly Alps Pointing-device for Vaio) appears in the new window, select it and click next.. (if the 'Alps Pointing-device' does not appear in the list remove the tick from 'Show Compatible Hardware' and select Alps Electric from the Manufacturer column then 'Alps Pointing-device' (possibly Alps Pointing-device for Vaio) from the model column and then click next.
Wait for the driver to install then click Finish, a System Settings Change window should now appear prompting you to Restart your Computer and click Yes to restart......
