Afternoon
I have recentley upgraded to Windows 7 clean install and would like to know what I need to download to get the function keys back?
using a vgn-aw11s vaio laptop
Solved! Go to Solution.
Hi wikey22,
To get the Fn Keys to work, you need to install the Sony Utilities IN THIS ORDER: -
1. 7UPG_Sony Shared Library
2. 7UPG_Setting Utility Series
3. 7UPG_VAIO Event Service
You can download these from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-AW11S_B&os=10
You may have to install the Utilities twice and you will find many other Windows 7 Drivers and Utilities on the same download page for your model.
Hi wikey22,
