Hi SamerDubai,
You should be able to launch Vaio help and support center from Start > Help and Support..:smileyconfused:
I thought the Vaio help and support program that is available via Vaio link is just an upgrade...
Check in your firewall settings that you have allowed the Vaio Update program VAIOUpdt.exe access the the internet...
Hi, First i am happy that such a forum exists which is active and the sequence of entries is que-ans-que-?, its good.
actually, i have the same problem about Vaio Update thing, i cannot connect it, it says server could not be accessed (its when i do start->all programs->vaio update 2 -> goto vaio web support. i shall mention that i ha´ve an german version which remains intact with additional windows xp prof sp2 on d:/ all drivers downloaded, so is this the problem.
i have some other ques too but will post in respective categories. thanxxx or just TX
Hi Hirendra,
You should be able download the updates for your Vaio from the Vaio-Link ...:smileyhappy:
Hi SamerDubai
You should also be able download the updates for your Vaio from Vaio-link..
another not helpful reply from thalamus.![]()
That was a bit rude SamerDubai - if you have a problem you should take it up with VAIO-Link.
Nico might want to look at this too
