Vaio/Microsoft Product Key Invalid?
DemonDave
Recently re-formatted my Vaio VGN-FW21L and have found the producy key for Microsoft no longer works for Office/Word.
Has anyone else had this problem? Does anyone know how to fix it? As usualy Vaio's help defies the word 'help'!!
Dave
8 REPLIES 8
Thalamus.
Champion
Hi Dave,
who did you purchase your version of Microsoft Office/Word from.?
DemonDave
Sony, comes with th vaio with product key underneath the Vaio
Thalamus.
Champion
Are you referring to the Windows 7 product key on the base of your Vaio.?
If so this is a Windows 7 Certificate of Authenticity code issued by OEM companies & would not work with Office.?
Did you purchase a copy of Office/Word from Sony or was it per-installed.?
DemonDave
Whatever came with it, the product key thats on the laptop worked on it previously, now since re-booting it doesn't.
Thalamus.
Champion
Hi DemonDave,
do you have more than one sticker/product key on the base of your vaio..:smileyconfused:
Usually Vaio models are sold with Office trail pre-installed - How to activate your 60-day trial version of Microsoft Office 2007?
If you suspect that the sticker on the base of your Vaio was an activation code for the copy of Microsoft Office/Word that was pre-instaled then all I can suggest is that you contact the official vaio support team for further advice..
Contact Sony support
DemonDave
I have one sticker on the bottom. I have already contacted them just awating a reply.
Whatever Word came on it previously, the key on the bottom worked with it, as I ran Office on the unti for close to 5yrs before re-formatting it.
Thanks Thalamus
Thalamus.
Champion
Thanks Thalamus
I would be interested in knowing the outcome, could you please keep us updated.?
DemonDave
Willk do bud
