vaio pcg-k115s
laferla
vaio pcg-k115s
I have had my vaio PCG- k115s for about a year. lately, on starting it i hear like a rininging alarm and it does not work well. For example the brightness adjustment goes dull alone. I upgraded and followed vaio links. every time it seems it will be fine but then it does it again.
Any help and advice will be greatly appreciated.
Thalamus.
Champion
This sounds like a battery problem to me, an alarm can sound when the power level reaches 10%
Try running MobileMeter and check you battery :slight_smile:
