Vaio PCV W1Display woes
wegit
:slight_frown: Just bought a vaio but i'm a bit dissapointed with the display options.
Basically, I like to use a high-res display with graphics programes, usually 1600x1200.
Now it seems I am stuck with 1280x768.
Is there anyway I can go beyond this setting ?
Wegit
stevep-4
If that is the resolution of thescreen as standard, then that is the best you will get. The documentation says 1280*768...thats it folks !!
wegit
Then is it possible to upgrade the graphics card ?
robpaxton
It has nothing to do with the graphics card - The display limit is defined by the resolution of your TFT display.
You should be able to get a higher resolution if you use a suitable external monitor.
