VAIO Peripherals Metadata 1.0.1.12090
oidestdroid
:thinking: Why won't update VAIO Peripherals Metadata 1.0.1.12090 install?
I have downloaded it manually & installed it or so I thought. Vaio update keeps listing it as an update.
Can anyone kindly assist?
Ta,
Oid :slight_smile:
tweety2b
Ex Commander (Was always on)
https://www.sony-europe.com/discussions/message/615317
You can find the answer here 😉
Cheers,
Nico
Nico Henderijckx
(ex-Sony employee - fanboy forever)
tweety2b
Cheers,
Nico
Nico Henderijckx
