Vaio Stopped Detecting Ethernet Cable
bjf02031986
I live in student halls where only have connection to the internet via Ethernet cables and for some reason it seems to have stopped detecting the cable.  I remember I had the same problem when I arrived and I think we eventually resolved it by disabling then re-enabling the adapter, but this time that doesn't seem to have solved it.  It also seems to have been triggered this time by a Windows (7) update, but doing a system restore doesn't resolve it.  The cable and wall socket both work and I've tried my laptop in different rooms but it still won't detect a cable.  I've checked device manager and everything seems to be functioning properly.  Any ideas how I can resolve this?
Thanks!
Edit: Strangely  just tried plugging it in a work and it detected it after disabling then re-enabling it, so it's definitely not a hardware issue
Message was edited by: bjf02031986
Thalamus.
Champion
Hi bjf02031986,
welcome to Questions & Answers..:smileyhappy:
I'm glad you were able to resolve your ethernet problem..:smileycool:
nikkilim
Hi. Try setting speed and duplex your ethernet card to Speed and Duplex: 10Mbps, Half Duplex.
This is under change adapter settings. https://imagicon.info/cat/12-13/vmware_happy.gif
Thalamus.
Champion
Hi bjf02031986,
