I have a new VGN NW20DEF. It is set to hibernate when I close the lid. Twice now I have discovered it had turned back on whilst the lid is closed, the first time it was quite warm inside. Last night I opened the lid after it was closed and made sure the screen was black and waited till all the sounds had stopped then closed it again. However this morning when I opened it it was on?? Is this a fault or something else? If anyone can help I would be very grateful.
Hi daveeeuk,
at a guess I would expect this is caused by something listed in task scheduler, media centre update possibly.
To open task scheduler go to Start, click on All programs, then click on Accessories followed by System tolls then finally Task Scheduler.
Hi daveeeuk,
Hi Daveeuk,
a quick search seem to suggest that these task may be linked to seems to IE 7.
Now you've disabled those tasks does your vaio hibernate successfully.?
Hi Daveeuk,
Hi Daveeeuk,
do you subscribe to any RSS news feeds as I think these User_Feed_Synchronization tasks may be related..
Hi Daveeeuk,
What do you advise me to do, enable or keep disabled.
