Vaio Update Error (VGN-SZ3XTP/C)
uaturk
Hello,
I have a problem with my Vaio Update 3. When I tried to update, I receive the following error message,
"VAIO Update failed to initialise for one or more of the following reasons:
You are not using Internet Explorer.
ActiveX have been disabled or the VAIO Update ActiveX is not installed on your computer.
You didn't start VAIO Update using the icon in the system tray or via Start -> All Programs -> VAIO Update -> Go to VAIO Web Support.
You tried to install VAIO Update on a computer that does not support it. "
I use XP Pro with SP2 (fully updated),
AVG antivirus Free edition (version 7.5.484),
IE 7.0.57.30.11,
I start Vaio Update (Version 3.0.00.13220) as described,
I use the Vaio update on my vaio..
So, I think the problem seems to be ralated with the ActiveX issue.
I read some information about it at the support, forum sections, but I did not find the exact solution. Anybody who help me?
Thanks in advance..
uaturk
Hello,
I uninstalled and re-installed the Vaio Update, now, the problem is resolved.
Thanks anyway..
