Hey,
I want to upgrade my laptop from 4gb to 6gb or 8gb is this possible if I take out the exisiting memory?
Model of Vaio I own is VGN-AW11S
Paul
Solved! Go to Solution.
Hi Paul,
The AW11 series only supports up to 4GB RAM - you already have the max supported.
http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-AW11%20Series&Cat=RAM
Rich
Hi Paul,
Rich
