Vaio VGN-FE41Z broken hinge and screen case
agerrard
I've got a Vaio VGN-FE41Z with a broken right hinge and screen  casing (the black bezel that houses the hinge strut from the main  chassis). Can anybody tell me the part numbers I need to replace them  and where I might be able to get them. Many thanks.
You would have to import parts from the USA and these can be expensive.
You will probably find eBay is the cheapest way ahead - have a look here: -
http://cgi.ebay.co.uk/Sony-Vaio-VGN-FE41Z-Laptop-Core-2-Duo-Spares-Repair-/260729911486?pt=UK_Comput...
:wink:
agerrard
That's a great answer - thanks. I'll check it out.
