Hi, I have a Sony Vaio VGN-NM20SF thats not well...
A Few weeks back i had an error msg come up saying that my HD was going to fail and i need to back up and replace,a day later the laptop died so i got a new HD put it in and re'installed from my backup,started doing the updates only to get the same error msg,now when i boot i get a msg saying S.M.A.R.T say my HD will fail and must backup press F1 to continue, it runs ok but on the desktop i get a msg from Intel storage thing saying i have a fault with my [NEW] HD and need to back up so i press the reset drive bit and the laptops fine till the next time it comes up then repeat..
Any one had this problem before and does any one have a fix for it...?
Thanks for any help...
