Vaio VGN-S5XP - High Definition Audio Driver
mlhuzzy
Good morning/afternoon all,
Help again, is needed. I'm sure this is a simple process of applying a driver to the device but I have applied all available drivers to this device but it still fails to work.
In my device manager the High Definiton Audio Control Device needs a driver applying - can anyone help me please? I'm running Windows XP 32-bit, SP3.
Any advice very welcome.
Thanks and have a great day.
MArtin
rich912
Hi Martin,
The driver is contained in the Original Drivers package.
http://www.sony.co.uk/support/en/product/VGN-S5XP_B/updates
Download the Preinstalled Drivers (Windows XP) > Original Drivers package.
The Audio driver and the UAA HD Audio Driver are part of the zip folder.
Rich
Go n-éirí an bóthar leat
11 REPLIES 11
rich912
Hi Martin,
I assume that you hve installed a retail copy of Windows XP?
If this is is the case you need to insall the Universal Audio Architecture (UAA) High Definition Audio class driver for Microsoft Windows after Windows XP setup
1. You must first install the Microsoft's KB835221 hotfix
2. Install the audio driver for your sound device
The hotfix can be found here:
http://support.microsoft.com/kb/835221
Rich
mlhuzzy
Hi Rich, this is great news, thank you. I have downloaded the FIX and applied that but the issue I have is that I cannot find the driver for this Audio device on the Sony website.
Any ideas?
Thanks in advance, I really do appreciate the effort.
Martin
rich912
Hi Martin,
Rich
mlhuzzy
Thank you Rich for the advice, but I have already done this. I downloaded the drivers you mention and within the Zip file there are 12 folders....10 folder called Utils Installer 1 to 10 and then a Wireless LAN Starter and Wireless Switch Setting Util folder - I have installed ervything from all of these folders but still this device won't install.
My bald spot is getting bigger where I'm pulling my hair out :slight_smile:
Any further ideas? Thank you again for your assistance.
Martin
rich912
Hi Martin,
From what you describe you have downloaded the Original Utility package NOT the Original Drivers package which has only 11 foldwers under Drivers - this includes the Audio Driver.
mlhuzzy
Ah ha, got it. The drivers you mention were under the Original Driver (without Bluetooth) section....downloaded and installed, thank you so much, it was driving me crazy.
All the best
Martin
rich912
Good to know that we got there eventually:smileyhappy:
THE WORST AFTER SALES SERVCE!!!!! I AM SO DISAPPOINTED BY SONY I AM ABOUT TO THROW AWAY MY NETBOOK
jumpsuit
Are you having trouble with high definition audio drivers annaabcdefg?
