VAIO VGN-TX2H | CPU higher than 80° C
Thalamus.
Champion
Hi SamerDubai
As you vaio is getting very hot, this could be caused by a build up of dust etc, check the air vents are clear and try moving the internal dust by gently spraying with compressed air..
If using the compressed air does not help I would contact Vaio-Link as soon as possible..:smileywink:
It may be wise to turn on the Power Managment as this may temporarily help to keep your laptop cooler..
Also you may wish to download MobileMeter, if you've not done so already
12 REPLIES 12
Thalamus.
Champion
Hi SamerDubai,
Agreed 79°C is not normal...:smileysad:
Good luck returning to the shopping centre.. :four_leaf_clover:
kee-lo_
I would reinstall those programs you removed and set the settings to full power.
frannys
Your CPU should not be more than 50c,it is running too hot,Something is obviously wrong with your system.80c is way too high and your proberly near burnout of your CPU.Take it back and dont let them give you the runaround.
kee-lo_
You should buy a desktop then, because there's no way you can run it at that tempreture
kee-lo_
Yes it can be dangerous, if it burns out.
Sony might not replace it either if they feel it's due to wear and tear or due to running it against their recomendations (I don't particularly agree with these, just passing the message on)
kee-lo_
Hmm think Mrs Merkle should talk to Blair so we can have that law too
jammold
Yes, however I can see the pigs flying mate:smileysad: :tongue: :wink:
kee-lo_
Wouldn't be good for his economy.
Anyway isn't it time he went?
Thalamus.
Champion
Hi SamerDubai,
Unfortunately Sony will not supply recovery DVD's in another language, see below..
The clear Sony policy on this reads, quote:
"Due to legal reasons and licensing agreements, VAIO Link cannot supply customers with Recovery CD-roms that differ in any way to the original product recovery CD-rom (i.e. different language versions, different model versions)."
