vaio vgn-tz1mn hard drive compatibility
profile.country.es_ES.title
Infodon
Hi all... i'm IT pro and need to upgrade hard drive of client's laptop to ssd unit. Since hd is ZIF interface i need a to know compatibility options.
I saw this :
http://www.amazon.es/KingSpec-D420-430-MK8009GAH-MacBook/dp/B009FX91YE/ref=sr_1_1?ie=UTF8&qid=136672...
and this one :
http://www.amazon.es/KingSpec-Disco-duro-para-Fujitsu/dp/B009FX92WA/ref=sr_1_5?ie=UTF8&qid=136672335...
Could they be good choice?...
Thanks in advance i would appreciate your help
El mensaje fue editado por: Infodon
Infodon
I will reply myself : I finally purchased the first option (64GB SSD). I can confirm it works perfectly . I'm updating W8 at this moment . Laptop works fast as espected.
Old HDD unit has been enclosed i n : KingSpec Mobile Disk ZIF 1.8" SSD Enclosure ... it works perfect and my client has now laptop completely updated and a new brand external disk working fine.
Hope this information could help someone thinking about to update his laptop.
BR
Infodon
BR
