For the last week or so my 3 and a half year old Vaio hasn't started properly. I press the power button, I can hear it start up but the Vaio screen doesn't appear. After reading another forum I took the battery out, pressed the power button for 2 minutes, then plugged the power cable in and it started. But this cannot continue.
Is it a battery problem?
The only programs I've installed receently has been a Sony Walkman one and a Samsung Kies one.
Thanks for any help you can offer.
Solved! Go to Solution.
Laptop now mended!
I took it to a bloke who rescued the data which cost me £30. Hard drive was ok.
Then I took it to another repairer (DEKK computers in Brighton) who sent it to a bloke who took it apart and reballed (resoldered) the graphics chip - apparently these ones commonly overheat andthe solder melts and stops the machine. This cost £80. So I've got my laptop back for £110. Not bad.
Hope this helps.
Hi shredhead2, do you only have problems starting your Vaio when using the battery?
This could be a screen/backlight problem, are you able to connect your vaio to an external monitor?
Laptop now mended!
Hope this helps.
