Hi Guys,
a couple months ago a solid white vertical line about an inch wide appeared on my screen. So I could then only use 3/4's of the display. About a week or so ago another line appeared but it isn't solid like the first and is about an inch away from it and the display behind the line is brighter than the rest of the screen.. I can only use just over half of the display.
Any ideas what it could be? The LCD display? Graphics card?
Any help would be appreciated.
Hi KroozaTypeR,
Attach an external monitor. If the lines are stiil apparent it is probably a graphics chip problem. If not then it will probably be LCD related - be it the screen or cabling.
Rich
Thanks Rich912.
Silly question but how do i connect an external monitor?
Dale
Hi KroozaTypeR,
His will depend on the external monitor but generally using the VGA out port on the AR.
Rich
