Good day
I just have recieved my notebook, but I found that the image of webcame is very bad and verrrrrrrrry dark even in light. Is any one face this problem? any one has solution of this problem?
thank you
Hi abdo9119,
I don’t have access to a Win 8 Vaio so have no idea whether there is any software included to adjust brightness etc. – I assume you have investigated this? The manual for this model is next to useless when looking for a solution!
Sony claim the camera works well even in low light – albeit on the USA site:
"Wondrous Webcam
The built-in HD web camera features a Sony Exmor® R image sensor which helps guarantee a crisp, bright picture—even in dimly-lit rooms. The webcam is perfect for snapping self-portraits, video conferencing with a client or catching up with your friends. And like magic, you can use the camera and a few simple hand gestures to skip a song, adjust the volume, navigate webpages and more without even touching your computer thanks to VAIO Gesture Control."
http://community.sony.com/t5/Windows-8/SVE14-Series-Discussion/td-p/42149
I suggest you take this up with Sony Support.
Rich
