very hot or normal?!
domestic705
hi all!
just wanted to know if its normal that my FE21s goes up to 75 degrees at 100% cpu load and between 40 to 60 degrees at normal loads .
thx!
75 degrees is a bit high but can probably be explained by the warm weather.
It's hot here but I bet it's even hotter in Tel Aviv !
65 degrees under normal usage is OK. You will know if it is overheating as your Vaio will become very slow and unstable.
:cool:
domestic705
thx for the answer!
and yes this summer is very hot in tel-aviv , can go up to 40 degrees:)
kee-lo_
Yeah it's very hot in Tel Aviv, my uncle's family are there and it's sweltering.
So 75C at 100% load isn't bad at all
