I have this registered in my windows 7 device manager. It is highlighed with the yellow triangular fault symbol and (code28) I have tried the "find driver" option with no success. The manfacturer is also comes up as unknown. The ony other information is Location. PCI Bus7 device3 function2. Could any body tell me what the item/ device might be and how locate/ install the missing driver for it.
Hi fadlock,
This is probably the memory card reader. Download the driver from here:
http://www.sony.co.uk/support/en/product/VGC-LV1S/updates
You will need to install the Vista version if there is no Win 7 upgrade.
Rich
